Hello folks, last night I spilled just a bit of soda on my Razer Blackwidow chroma, I immediately unplugged the keyboard and it still registers keystrokes and the lighting effects work fine. However the soda has left a couple keys lacking there tactile bump. I I fully cleaned the keyboard, soaked the key caps, dropped a little bit of rubbing alcohol into the switch. This perfectly fixes the problem for about 20 mins, then I lose tactile bump and in 3 or so hours the key takes a good second to come back up once pressed. Is there a more permanent solution for this?
Any and all advice is welcome. Thanks.
https://linustechtips.com/topic/706982-solution-for-sticky-keys/
I would dissemble it as much as possible and soak all the parts in 99% isopropyl alcohol. That should fix it.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/706982-solution-for-sticky-keys/#findComment-9031231
Just now, ShadySocks said:
Probably your best bet +1
Seems to me that since Alcohol is acting as a lubricant which means it's obviously getting well into the switch. It seems that all I would need to do is find a liquid that would break down the sugar for good but also not brick my Blackwidow.. ?
https://linustechtips.com/topic/706982-solution-for-sticky-keys/#findComment-9031247
Alcohol evaporates nicley, that is what the smell is.
https://linustechtips.com/topic/706982-solution-for-sticky-keys/#findComment-9031257
Just now, Bookhugger said:
Right so as soon as the alcohol evaporate it no longer lubricates the key and it becomes sticky again :/
The reason for the alcohol is to transport the sticky away, however that is a valid statement.
https://linustechtips.com/topic/706982-solution-for-sticky-keys/#findComment-9031274
I would also suggest the 99% isopropyl alcohol (swipes) suggestion. Saved sticky keys for me countless times.
https://linustechtips.com/topic/706982-solution-for-sticky-keys/#findComment-9031321
