Bottleneck?? Or driver problem? Or something??
Hello, I just installed my GTX 1050ti in my AMD A10-7850k, 8 GB ram system and it replaced my GT 720. I play csgo so frames are important. When I was playing almost maxed out 1080p I was only getting sub 90 frames. I lowered some settings 100 and lower. My friend has a A8-7800 GTX 1050ti and easily pulls 100+. I tried a few different titles and they all ran perfectly. Redout ran maxed out 60fps 1080p. So does anyone know the problem could it just be a CSGO issue or a bottleneck which makes not a lot of sense saying as the A8 to my knowledge is weaker... All replies are appreciated
https://linustechtips.com/topic/706901-bottleneck-or-driver-problem-or-something/
Just now, Droidbot said:
do you have launch flags set?
right click on csgo in steam, then hit properties, then hit 'set launch options'
put in the box "-high -threads 4", hit ok
then restart the game
I have high threads 4 on, I tried so much and did so much to boost fps on csgo, maybe I should fresh install?
