Is it possible if I buy a wifi power outlet/switch (example) to turn on my PC at home from the office? If I active the switch with the app at the office, my PC at home turns on and logs in automatically and I'll be able to connect to my PC with teamviewer for example.
https://linustechtips.com/topic/706211-remote-control-turn-on-pc/
Only way i can think of doing so is remote accessing the PC, and telling it to shut down, or get a plug, have a ups that has software to auto boot down when power is lost and then have that be plugged into the remote plug.
Wake on lan is also a thing.
or you can schedule a startup in the BIOS
Look up WOL (wake on lan). Most modern motherboards will allow for this. Then just send a magic packet to your home network and port it to the PC you want turned on.
You can also just let your computer sleep rather than turn off in which case trying to connect to it with a remote desktop will wake it up and allow you to connect.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Wake on LAN does not support by all motherboard. Double check it. Not all mobo support this
Mine does but have no time figuring that out and I don't want someone attacking my own network to suddenly power it on and waste my electricity bill
Go to BIOS and see if your mobo has that feature
If your motherboard supports it, you could specify a SecureON Password, which essentially password protect your WOL.
all modern motherboards support it, actually. It's become a standard BIOS/UEFI feature
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
6 hours ago, ddix0n said:
Can it be used when the PC is on a different network? Because all the apps in the app store can only use it when it's on the same network.
Back when I did it (before I had a server that stayed on all the time), I did the following:
First, use a wired connection between your computer and router.  In your motherboard BIOS, make sure WOL is enabled and set a SecureON password if your board supports it.  Then reboot and go into your router settings.  Set a static IP for your computer.  Then forwarded port 9 to the static IP you set. Before leaving the router settings, take note of the MAC address for your computer, as well as the WAN IP address for your network, you'll need both later.
Then open a WOL app.  Enter the WAN IP of your network, the MAC of your computer, port 9, and the SecureON password.  This should now wake the computer when you're outside your local network.
Thanks a lot for this explanation! When I get home later I'll try this out and report back.
