PCPartPicker part list: https://pcpartpicker.com/list/KFYNYr
Price breakdown by merchant: https://pcpartpicker.com/list/KFYNYr/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($159.99 @ Newegg)
Motherboard: Asus Z170-AR ATX LGA1151 Motherboard  ($158.75 @ OutletPC)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  ($109.89 @ OutletPC)
Storage: Sandisk X400 512GB M.2-2280 Solid State Drive  ($142.99 @ Amazon)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($414.88 @ OutletPC)
Case: Phanteks Enthoo Pro ATX Full Tower Case  (Purchased For $0.00)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $0.00)
Case Accessory: NZXT Hue+ LED Controller  (Purchased For $0.00)
Other: Custom GPU Backplate ($40.00)
Total: $1026.50
Generated by PCPartPicker 2016-12-12 21:39 EST-0500
Notice the purchased parts, and looks do matter to me.
for 1440p gaming, upgrading from i5 4690k and GTX 970.
Will add other drives and maybe SLI in future.
thoughts?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/706028-build-plan-thoughts/
1 minute ago, deXxterlab97 said:
If you waited a bit you could have gotten the special edition white Corsair RMi
Considered Corsair Vengence LED white RAM?
Looks nice so far
Not a fan of corsair RAM, I did consider Geil SUPER LUCE though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144828&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I have been told the TridentZ is super nice and will perform better, and it looks pretty sharp.
besides, with a HUE+ (and Kraken x62 (and NZXT AERs in the future)), the white LEDs would look odd among the RGB
Solitaire.
https://linustechtips.com/topic/706028-build-plan-thoughts/#findComment-9020265
8 minutes ago, MaxCraft said:
If your sticking with a Z170 board you can spend about $ 20-30 dollars more on the ASUS sabretooth Z170, it might match you white themed build better.
Not a huge fan of the white/gray camo, but I did consider the MSI Krait X3, or a slightly more expensive ASUS board.
Solitaire.
https://linustechtips.com/topic/706028-build-plan-thoughts/#findComment-9020357
