4 minutes ago, Himommies said:
Somebody who got it right the first time congrats!
though i would get a Atx mobo because the small one loks awkward but hey if that's what you like
I agree, if you can afford it. Also, get a SanDisk ssd, the guy I talked to at Microcenter said that Sandisk is more reliable than PNY/Adata/Most other brands. But other than that Really great build one of the better ones I have seen at that price.
https://linustechtips.com/topic/706016-build-help/#findComment-9020009
Samsung is probably the most reliable
My life
https://linustechtips.com/topic/706016-build-help/#findComment-9020023
I went overbudget (My Bad) But if you don't mind spending a little more, you could get a really nice gaming rig.
PCPartPicker part list: https://pcpartpicker.com/list/rH89wV
Price breakdown by merchant: https://pcpartpicker.com/list/rH89wV/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($191.91 @ Jet)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  ($46.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($79.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Mini ITX OC Video Card  ($383.89 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($52.89 @ B&H)
Monitor: Asus VS247H-P 23.6" 1920x1080 Monitor  ($109.99 @ Newegg)
Keyboard: Rosewill RK-9000V2 Wired Standard Keyboard  ($69.99 @ Newegg)
Headphones: Logitech G430 7.1 Channel  Headset  ($37.99 @ Newegg)
Other: Windows 10 ($28.09)
Total: $1163.48
Generated by PCPartPicker 2016-12-12 21:06 EST-0500
lttstore.com
https://linustechtips.com/topic/706016-build-help/#findComment-9020034
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($59.99 @ Best Buy)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($239.99 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Monitor: Asus VG245H 24.0" 1920x1080 75Hz Monitor  ($149.99 @ Best Buy)
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse  ($28.99 @ SuperBiiz)
Other: Windows 10 (KInguin) ($28.09)
Total: $1020.69
Generated by PCPartPicker 2016-12-12 21:08 EST-0500
https://linustechtips.com/topic/706016-build-help/#findComment-9020044
Total: $1020.69
someone listened to me and took my advice with free sync
https://linustechtips.com/topic/706016-build-help/#findComment-9020051
sounds stupid not to pair up a freesync monitor with an AMD graphics card. don't worry man, i'm not linus enough xD
https://linustechtips.com/topic/706016-build-help/#findComment-9020057
it's fine having a 1060 and no free sync.
it's not fine having a case with no external optical drive slot or a 1070 with a EVGA 500b
https://linustechtips.com/topic/706016-build-help/#findComment-9020068
15 minutes ago, deXxterlab97 said:
I would try and get a mechanical keyboard if you can. If you want there are always cheaper case to consider at.
Also the monitor has free sync. It would be a mistake not to get RX 480
im quite the amateur when it comes to computers. Would the Rx 480 get substantially better performance with this monitor? and also what other monitor would take better advantage of the 1060
https://linustechtips.com/topic/706016-build-help/#findComment-9020095
G sync monitors with NVIDIA gpu are EXPENSIVE AS HELL
Free Sync allowing you to play games with AMD gpu smoother and nicer
https://linustechtips.com/topic/706016-build-help/#findComment-9020102
1 minute ago, Gwish said:
which version of the 480 would you recommend the most
red devil's a good value right now.
https://linustechtips.com/topic/706016-build-help/#findComment-9020148
it's not fine having an optical drive with a case with no internal optical drive slot or a 1070 with a EVGA 500b
no point getting a freesync monitor with a gtx 1060 imo, just get a regular ips monitor for less and use the money on something else. i'd usually hesitate putting a 500B on an rx 480, let alone the gtx 1070. xD
https://linustechtips.com/topic/706016-build-help/#findComment-9020170
3 minutes ago, Gwish said:
alright I've taken in all your suggestions and i've come down to this: https://pcpartpicker.com/user/Gwish/saved/#view=zg8rHx
it still lacks a case, i have no idea which cases fit what so what case would fit this build for relatively cheap?
https://pcpartpicker.com/product/xPs8TW/azza-case-csaz208s
https://pcpartpicker.com/product/v6w323/rosewill-case-rangerm
These ones should do
https://linustechtips.com/topic/706016-build-help/#findComment-9020196
deepcool dukase is $50 and really good if you can afford it. otherwise, i'd recommend thermaltake's versa H cases and the deepcool tesseract.
https://linustechtips.com/topic/706016-build-help/#findComment-9020220
NZXT S340 is a great case, or so I've heard.
https://linustechtips.com/topic/706016-build-help/#findComment-9025452
