Fan Orientation help!
Solved by slightlyjaded,
Just now, Jason_Tan_ said:would adding 1 140 as intake towards the front and the back 140mm as exhaust present any problems?
fan support is listed as 2 x 140mm in the top, if you can get some seperation between the two then maybe, otherwise I'd avoid having an intake right next to the outlet as I could see the turbulance puishing half the air from the front fans under the graphics card with no easy way to escape.
