Hello , I'm planning to build my own gaming pc with a budget. I want to know what you guys think about it and if you have, some advice
I want that my games just run at max settings at 60fps at 1080p. The parts in Belgium are more expensive than in the USA or in Canada.
I've checked the parts so it's compatible.
I want to play arma 3 on max and i would want to record it. Could I do it with this build ?
Here is the link : https://be.pcpartpicker.com/list/9x8KsJ
https://linustechtips.com/topic/705413-my-lan-pc-build/
Might not want to spend that much on the OS.
https://www.kinguin.net/category/19429/windows-10-professional-oem-key/
https://linustechtips.com/topic/705413-my-lan-pc-build/#findComment-9013264
14 hours ago, chris76816 said:
Looks good, you should swap out the 850 pro for an evo because it won't affect any gaming performance and it is cheaper than the 850 pro.
Yeah i know but with the 850pro  I found a website with 10 year warranty on the SSD.
https://linustechtips.com/topic/705413-my-lan-pc-build/#findComment-9015974
