Hi all,
As per subject I would want to change my current CPU liquid cooler (H50) with something like H105, H100i or Nepton 240M.
I have a i7 3770K, I don't overclock it, I'm just looking for something to keep it cool and silent even when the load is 100% on 4 cores; the case I have is a Cosmos 1000.
I use Ubuntu 16.04 and I've read that Corsair software is not supported on Linux (or better, Corsair hasn't released the USB specs hence lm-sensors doesn't properly work out of the box).
I'm tempted to go for the Nepton 240M but quite frankly I'm open to any suggestion!
What would you recommend and why?
Thanks - I'm a bit lost at the moment...
https://linustechtips.com/topic/704704-help-cpu-liquid-cooling-on-linux/
Why don't you get a fat air cooler? should solve the problem of usb support, is dead silent and cool too. Something like the dark rock is very silent and I'll bet more silent than any aio.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
You would have to control the fans on the Corair cooler by plugging them into and controlling them with the mobo or a fan controller rather than directly into the cooler.
if you're not going to OC anyway you're probably better off just going with a decent air cooler though.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
@19_blackie_73 @pyrojoe34 Wouldn't the liquid cooling solution improve the airflow into the case? I was also told this solution is more silent than air cooling...
I also have to say I find it more elegant, hence what would you recommend which isn't noisy and doesn't have to be software controlled (or at least supported on Linux)?
1 minute ago, em4n3m said:
@19_blackie_73 @pyrojoe34 Wouldn't the liquid cooling solution improve the airflow into the case? I was also told this solution is more silent than air cooling also...
no not really, if you really want more airflow, just take another fan and put it anywhere in that case. Who told you bout the silence? yes, they are at points more silent than a entry level air cooler with an 3000rpm fan, but if you get a dedicated silent air cooler like the dark rocks, aios are actually louder. reasons are for example the noise of the air through the rads and pump noise.
- Ryzen Build -
2x Dell UP2516D
It depends, a liquid cooler will generally be quieter than an air cooler but a good air cooler with a good fan can still beat out some liquid coolers. That's too general of an assumption. I do think liquid coolers look better though. Either way you should be fine. You'll just have to control the fans in the BIOS rather than with software.
Putting in a couple case fans in place of the liquid cooler would give you better airflow though.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
Just now, em4n3m said:
@19_blackie_73 Although your argument is almost convincing (and I'm genuinely thinking about it), what would you pick in case of liquid cooling?
Whatever you find more aesthetically pleasing. As long as it's a decent company the biggest difference is usually in the aesthetics.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
@pyrojoe34 So all the three cited coolers are equal in terms of noise levels? Any other suggestion (my budget is around 100 GBP tops)?
That will depend mostly on the fans, not the cooler. Stock Corsair fans are pretty loud (not sure how the Nephron fans are) so many people choose to swap those out for something quieter. Then again without any overclock the fans will probably never have to go above 40%.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
  • 1 year later...
