https://uk.pcpartpicker.com/list/sBhVm8  this is my first ever pc build. i would like to know if i could make any thing better for around the same price. it needs to be ddr3 as i already have the ram as i have been given it any don't wont to by a new one. i would also like to stick to a nvidia gpu thats why i dont go for the the rx 480. thanks for the help.
https://linustechtips.com/topic/703972-first-build/
Add an SSD and if you haven't already bought Windows then just get a key from kinguin for cheaper. And you don't need a optical drive.
https://linustechtips.com/topic/703972-first-build/#findComment-8998061
Looks good overall.
But no ssd? You should defenetly add atleast a 120gb one
https://linustechtips.com/topic/703972-first-build/#findComment-8998065
For all you know he could need an optical drive.
Adding an SSD would be good, bit weird you didn't put one in when its a £1k build.
https://linustechtips.com/topic/703972-first-build/#findComment-8998069
Some people might still use them :P
and considering he dosent have a price on it makes me think he owns it already
https://linustechtips.com/topic/703972-first-build/#findComment-8998070
Just now, deXxterlab97 said:
you are paying a bit too much for the ram and that case is not so good
also if you tell me the ram is beautiful then no. your case has no side panel to look at it
other than that looks fine
i was given that ram. saves me from bying it
https://linustechtips.com/topic/703972-first-build/#findComment-8998092
