Ive been having many problems with my computer booting up. I have windows 10 installed and it would give me blue screen errors on startup related to memory isues and now i have plugged in a hdd with ubuntu installed and its giving me this error message on startup:
I ran the ubuntu memory check feature and i get no errors even after 2 hours of running the check
does anyone know what any of this means?
https://linustechtips.com/topic/703247-computer-not-starting/
disable fast boot if currently enabled, and maybe try a linux usb boot drive instead of a full installation for another system (unless the current hdd with ubuntu was installed through the problematic system)
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/703247-computer-not-starting/#findComment-8988574
fast boot is disabled and i have tried it with a usb drive install, it gives the same error
https://linustechtips.com/topic/703247-computer-not-starting/#findComment-8988592
Assuming you have more than 1 ram stick, have you tried using just 1 stick at a time in different slots to get past startup at least?
https://linustechtips.com/topic/703247-computer-not-starting/#findComment-8988600
