Ok, I really need some help. I just bought an MSI GTX 1080 Founders Edition from Amazon and I have spent the past 2 days trying to get it to work. I got it installed and all the drivers installed without issue, but as soon as I rebooted the computer and hooked up my three monitors(1 HDMI Ultrawide, and 2 16:9 DVI one of which is running through a display-port adapter), all to the the 1080s IO. Windows became unusabley laggy. I had to pull all the monitors restart and plug into the motherboard's HDMI to get it back up. Since then it's been a whirlwind of unistalling and reinstalling drivers, testing, my computer refusing to output anything on the 1080. Finally when I was able to get windows semi-stable enough to use with the 2 16:9s plugged into the card(don't ask me how I don't know and was never able to replicate it), and I launched Premier Pro to test it out and this happened on both screens.
I really need to get this fixed as my computer is essentially out of commission right now. What is going on? I have exhausted my knowledge of PC configuration, so I turn to you the LTT forms for help.
PC config:
Intel i7-3770K
ASUS P8Z68-V Pro Gen3
16GB
Old Graphics Card: Original GTX Titan
1x SanDisk 256GB SSD,
2x 1TB HDD
Windows10
https://linustechtips.com/topic/703224-gtx-1080-help/
