Hi all, I built my PC in 2014 with 1x stick of 8GB RAM with the idea that if I need more later I can add another stick of the same when I need it. Judging by my high RAM usage percentage recently in games I'm think it's time to upgrade to 16GB.
Can I just by another stick of 8GB and chuck it in with the old one? Does it have to be the same brand/model etc?
The kit I bought in 2014 is Kingtson 8GB KTH9600C/8G DDR3 SDRAM KTH9600C/8G and I believe it may now be discontinued. Do I need to get another stick of the exact same to run along with my old one, or should I buy whatever is newer which seems to be Kingston 8GB DDR3 PC3-12800 1600MHz Single Rank Memory KTD-PE316S/8G? Will they run together? The latter appears to be AU$139 rather than the former which is AU$79.
Any advice would be much appreciated :)
James
https://linustechtips.com/topic/702870-ram-upgrade-same-model/
As long as they are the same speed, type, and what not they should work. I've tried literally every different combination of DDR2 and everything worked. Just take a look at the LifeHacker article.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/702870-ram-upgrade-same-model/#findComment-8983946
