Hello, I am a 3d artist and I use mice with a lot of buttons for shortcuts in my programs notably 3ds max. Currently I am used to my logitech g602 which has 8 extra buttons and i would have a hard time using a mouse with less. Yes I do use those 8 buttons.
I will soon enough get a job in the field and have the ability to choose a mouse. I don't want to get the same mouse again because there might be better options and i want a wired mouse for work so there aren't any awkward no battery situations.
I will need the mouse to have a fairly durable middle mouse because i click a lot with it and shouldn't be too stiff. I have a claw grip even with the g602 but my picky feels slightly awkward at times with it.
While searching around the internet, i found a couple mice but i don't  have any experience with them. All the stores here in Bulgaria I visited have them behind glass.
logitech g502 - praised ergonomics but only 5 buttons and scroll side to side which makes me think the scroll will fail quickly.
Naga/G600/scimitar - tons of buttons but looks like it won't be easy to grip due its width and finger rest positions
Roccat nyth - quite a bit more expensive in comparisson, similar to the above category, more customizable, don't know too much otherwise
Corsair m90/95 - looks pretty interesting but the reviews are slightly mixed. Being heavy, quirky glide pad and grip? Very curious about this one,
Roccay tyon - instantly brushing of mice with buttons on the right side or behind the middle mouse. Too awkward to use.
How would do you feel about their weight as well? My g602 weights 133 with 1 battery (how i use it).
Any experience with these mice is welcome, the more the better :)
https://linustechtips.com/topic/702816-multi-button-mouse-for-work/
Nah I am a right handed. what would you say about its weight and sliding pads, they look small. Some sources say 140g, others 160 and third 180... Would be epic if you could weigh your mouse.
My mouse is 161 with both batteries. Just by testing it now its manageable but i am starting to feel the weight difference. As a reference I don't have small hands nor am i a skinny person.
