Hi everyone. I am really amazed by my new pc. But I installed windows 7 Professional 64bit as my OS in my system. And I tried to run games like rise of the tomb raider,mirrors edge catalyst and they really work. But when it comes to dying light,GTA 5, Alien Isolation and other modern games it seems that I get this error 0xc000007b was unable to start correctly. Is there a missing file in my windows or any other problems? Please help me fix this thanks :)
https://linustechtips.com/topic/702363-0xc000007b-error-please-help/
This error is caused by an application loading the wrong dll for the bit structure that's in use. As in loading a 32bit dll when in a 64bit environment.
Reinstall .NET.
If that doesn't work, reinstall game.
If that doesn't work, try running game as admin.
if that doesn't work, reinstall DirectX.
Also restart after each uninstall and install.
Edited by APasz
Add information.
-アパゾ
1 minute ago, Jordan Gulrajani said:
Yes I already installed. But maybe I didn't install my i5 6400 yet. where can I install that?
there are bios updates, but I don't think theres any CPU drivers. with a brand new processor and motherboard I can't see why you'd need a bios update.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
2 minutes ago, APasz said:
Reinstall .NET.
Can you give me the links for the installations thanks :). I am already running my games as admin and still dosen't work by the way
You install your CPU inside the socket in your motherboard, and you've already done that since your PC wouldn't be running otherwise.
But yeah as the other dude said, installing .NET framework has a good chance of fixing this.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
Hey megah3rtz. do you have any ideas how to solve this problem?
I believe steam handles this most of the time.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
Here you go, mate.
digging around brought up this, I'd be very careful if you decide to do this. Messing around in System32 might brick windows. TRY THIS LAST, IF NOTHING ELSE WORKS
"This error message may occur (The application was unable to start correctly (0xc000007b) on 64 bit operating systems when the Microsoft Visual C++ Redistributable Package is not properly configured.
1. Replace these files. mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll
They can be found at http://www.microsoft.com/en-us/download/details.aspx?id=5555
Please save these files to any location on your PC;
2. Please reboot your computer in Safe Mode
[How to restart in SAFE MODE]
- Restart the computer;
- Press the "F8" key (several times before Microsoft Windows begins to load; you need to press "F8" until you will be displayed a text menu;
- Select "SAFE MODE";
Note: for Windows 8, you can hold the Shift key while going to Power Off and clicking on Restart option
3. Access C:\Windows\System32;
4. Locate the 5 files you have downloaded and extracted;
5. Next, copy all those files to C:\Windows\System32 replacing the current ones;
6. Reboot in normal mode"
"This error message may occur on 64 bit operating systems when the Microsoft Visual C++ Redistributable Package is not properly configured.
I will try this later. Thanks mega for the informative instructions I hope this works :D
