1 minute ago, Droidbot said:
better off building something in a sff case with a sfx psu, they're smaller than atx and really nice PSUs, you will encounter power issues with picopsus with such a setup
to big with sfx psu i need very small pc with dedicated gpu
like nfc case xD
https://linustechtips.com/topic/702348-picopsu-and-hdplex/#findComment-8977627
My experiences with PicoPSUs have been varied. When they work, they work well. But I've had multiple occasions where I've had to RMA multiple PSUs before I had one that actually was up to spec...
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
https://linustechtips.com/topic/702348-picopsu-and-hdplex/#findComment-8977673
The picoPSU will overheat... you'd still need a fan to cool it down and that negates the savings in "volume" inside the case.
In addition to that, that passive laptop adapter that outputs 192 watts would probably die within a year if you're constantly stressing it with a power consumption higher than let's say 120 watts. Even with 90% efficiency, we're talking about 10-20 watts of heat dissipated inside that plastic box, the insides would be constantly at 70-90c cooking the capacitors and degrading the thermal pastes used to transfer heat from mosfets or whatever to the tiny heatsinks inside the plastic case.
r9 nano and gtx 1070 by themselves use around 150 watts from 12v, the motherboard and that cpu would use around 60-80 watts, so anyway it's not really doable.
Stay away from picoPSUs for anything higher than around 100w, and even then they're not really worth it.
By the time you get to a such low power computer, you're getting into the territory where you can buy motherboards with processors soldered onto them with decent integrated graphics and which are cool enough that they can work with just a passive heatsink. Also, those motherboards can have DC In jacks, so you can plug directly a standard ~18v 65w laptop adapter and get the system working in a few minutes.
https://linustechtips.com/topic/702348-picopsu-and-hdplex/#findComment-8977773
