Has to be a GTX 1080 to SLI with your card, but brands don't matter
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8963618
15 minutes ago, Reflecting said:
Because many of us like the performance of having 2 cards when we can take advantage of it. Why does it matter why he wants to run 2 anyway?
Pascal's SLI scaling is terrible at low resolutions with only about a 25% gain for a 1080 SLI at 1080p (discounting games that didn't scale at all) and a max of  71% gain at 4K 60Hz (again discounting non-scaling games). While the 71% at 4K sounds appealing, but this is only in games that support AFR and multiple GPUs in DX11.
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1080_SLI/20.html
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8963985
2 hours ago, flyingsnow89 said:
Hi people, I would like your help with something. I have a gtx 1080 nvidia. i am wanting to buy another 1080 but i cant find a nvidia card anywhere anymore. So my main question is can i do sli with my current 1080 with another card? If so how do i go about it.
What resolution are you looking at?
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8964226
I'm glad you can simply regurgitate what others say with no real knowledge for yourself. Please educate yourself a bit better then return to this forum with out giving such horrible advice as you have on various threads.
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8964859
Any Graphics card with a GTX 1080 chip inside can be SLI'ed with  yours. You can use any other card, but it'll look so weird.
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8965797
People expect 100 percent scaling but don't apreciate the fact that it's harder for a gpu to get from 120 to 130 fps than it is from 60 to 70
that why they scale better at 4K
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/701043-gpu-sli-help-please/#findComment-8966223
