hey there i have a question/problem my i5 6600 lags or something like that when i have origin open and downloading a game and playing forza horizon 3  and have chrome open  i mean like in forza like  i have 50 fps and its like stuttering is that normal ? i rlly dont know before i had a amd fx6300  and i think it didnt stutter or lag idk.
btw pc specs:
CPU: I5 6600 (water cooled)
MOBO: MSI Z170 KRAIT GAMING x3
GPU: MSI GTX 1060 OC 6GB
RAM: CRUCIAL BALLISTIX LT SPORT 24GB DDR4 (dont ask why)
SSD: Samusng 850 EVO 250 GB
OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/700872-i5-6600-multitasking-problem/
Did you do a clean install of the OS?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
1
There is your problem
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Just now, CrazyHKS said:
yea i  did  i mean i fresh built the system  and then i had windows problems and i like  reinstalled and 1 time i had to do it again and i did also download al the drivers for my mobo
If you had issues with your SSD, I would run a "clean all" through diskpart. Back up whatever you need to and use another PC with SATA cables to do so.
it wasnt an ssd problem it was windows it was buged like sometime start menu wouldnt open and random stuff like that
2 minutes ago, CrazyHKS said:
why would that be a problem i could run any game on my amd and have chrome open and it would work fine
Downloading a game will use up CPU IO cycles then you're loading graphics of a game == laggy game.
28 minutes ago, CrazyHKS said:
oww okei  well i thought an i5 would be perfect for gaming and stuff like i mentioned but i guess not :/
The CPU isn't the problem even on an SSD there is only so much data you can transfer as once downloading and gaming uses up both read and write streams. Try without anything else going on and see if the problem carries on.
if im not downloading it works normal  well i think so and if i play with both closed its perfectly normal
Then we can conclude it's a read/write bottleneck.
When you're on FH, do you mean online?
12 minutes ago, CrazyHKS said:
but how is that possible  this ssd is like rlly good  i mean not the best but u know what i mean
well a sad can read/write x amount of data per second this with your cpu having to do I/O not only reading your game but also writing the download. While its doing I/O it can't progress the game hence the lag.
mhm  i understand now  so if i get it right if i buy like a new ssd or hdd and put the game on there the lag would be no more if i am  correct
you're still doing the same I/O but now it's over two drives which will give more bandwidth and should be better.
