TP link access point wireless authentication help
Solved by Eniqmatic,
Just now, Jekub said:I'm not home right now but I believe it can be disabled through the TP link web UI ans yes that's exactly what I'd like, is this set up through PF sense?
I've had a look at the manual, from the pictures it looks like you can disable "portal" on an SSID. So edit your SSID and set the portal to disabled. That will change it back to a normal access point without having to login to the internet page. Then do nothing on PFSense if that is how you want it.
