Hello all, I'm currently playing BF1. I play on 1440p with the settings set to ultra to high.  While playing BF1, I notice a yellow flashing symbol on my monitor. I understand what the symbol means but I don't understand get how I'm getting low FPS.I also notice sometimes my screen stutters and lags.  I have a pretty high end system
My specs are as follows. I5 quad core at 3.50Ghz ,Ausus Strix 1070 OC edition, 16Gb of DDR3 memory, a 3 TB seagate Barracuda gaming hardrive. My monitor is a  Asus MG28U UHD 4K monitor. 4K at 60Hz. I don't play at 4k because the  GPU can't handle 4K with decent FPS, so I turned it down to 1440P. I use a HDMI 2.0 cable for the display. My FPS counter never goes below 60FPS at the settings listed. Yet I still encounter the problems I have listed.
Do I need a monitor with a faster refresh rate,one  with Gsync?Or do I turn the setting down lower.
Any help would be much appreciated!
Thank You.
https://linustechtips.com/topic/700758-low-fps-on-bf1/
Thank You.
I thought that usually meant that you are having trouble connection with the server not fps issues.
https://linustechtips.com/topic/700758-low-fps-on-bf1/#findComment-8960417
Thank You.
Screen shot it happening pls
https://linustechtips.com/topic/700758-low-fps-on-bf1/#findComment-8960422
