This is my first build. I plan on gaming, streaming, recording, editing, and just general everyday tasks. Will this work? Any suggestions?
https://pcpartpicker.com/list/QwwJkT
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/700396-first-build-reccomendations/
Just now, TheNuzziNuzz said:
Budget? Monitor/s?
I already have monitors, and my top budget is around $1000, but I would like to have room in there for an Elgato HD60 Pro.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
Yup, looks like a pretty good build.  You should have no problems with 1080p gaming at 60 fps at or near max settings.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
What NVIDIA card is this equivalent to? Just curious
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
Just now, RKRiley said:
the 470 is between a 1050ti and 1060, more towards 1050ti, but better. if that makes sense lol
Ok. Thanks.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
But the real question. Can it run minecraft on high settings at over 60 fps? While recording, and skyping?
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
1 hour ago, KeFy said:
basicly a potato can run minecraft at 60fps so yes
1 hour ago, deXxterlab97 said:
I would get 480 or 1060 3gb even
1x8 ram for future
1 hour ago, TheNuzziNuzz said:
Budget? Monitor/s?
How is this? https://pcpartpicker.com/list/tJ4Ym8
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
4 minutes ago, Chaos Network said:
Why so expensive?
https://pcpartpicker.com/list/y2kNgL
Use OBS  to screen record, that capture device isn't worth the 200 when you can put that towards an i7 and a 1070!
https://obsproject.com/
To save money, you can get an i5 instead of i7, or 1060 instead of the 1070.
Computers r fun
3 minutes ago, TheNuzziNuzz said:
Why so expensive?
I don't plan on using that to capture my screen. That's for my consoles.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
Putting it under PcPartPicker is misleading because its not for the computer. It would be much appreciated if you supplied this information prior to any responses.
Computers r fun
It goes inside the computer. It's pcie based
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
