Help! Ethernet Switch 101
Go to solution Solved by AshleyAshes,
2 minutes ago, benjamin051000 said:
Can you daisy chain them together? In case I for some reason needed more than 8 ports
Yup.  You know those four ports on your router?  Those are also a switch. The router has a switch built that gives it four ports (Well they USUALLY have four.  Some really do have just one...)  By hooking up another switch to your router, you are already daisy chaining and you can daisy chain more.
depending on how big your network gets and type of traffic each game generate, you might want to throw a couple of routers in there to break up the broadcast domains, but you should be fine with a single 48 port switch, assuming you don't daisy chain too many of them.
