Recommended Battery Charge %?
Some people say 40-80. Some say don't worry about it until it gets low and then charge to 100%. I was wondering what's best for preventing the zero point from getting muddled on my mouse battery (mx master)
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/698908-recommended-battery-charge/
100%
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
If you are storing the battery, for the maximum possible life it should be kept at about 40-50%.
If you are using the battery, it practically doesn't matter. Let see if I can put this in an example that may make sense.
In some first person shooters, you have a pool of ammo. You can reload your gun at any point and all you're doing is transferring from the pool to the magazine. In other first person shooters, if you reload, you discard what was left in the magazine and load up a new magazine from the pool, effectively wasting ammo. Lithium Ion batteries work like the first way.
9 minutes ago, M.Yurizaki said:
...You can reload your gun at any point and all you're doing is transferring from the pool to the magazine.
...You reload, you discard what was left in the magazine and load up a new magazine from the pool, effectively wasting ammo. Lithium Ion batteries work like the first way.
Good explaination
#2 is nickel batteries, correct?
