1. Question:  In a series circuit that has one cell, a switch and two bulbs. Describe the brightness of each bulb.
I don't really get this question, but I know the bulb closest to the negative side of the cell will be the brightest, but I don't understand why.
2. I also have another question:  in a parallel circuit that has two cells, a switch and three bulbs (each on their own branch of the circuit).  Describe the brightness of each bulb.
Now in this question I have no idea which bulb would be brighter, but in a parallel circuit how would a switch work? wouldn't it have multiple paths to flow from if the switch was open, would the switch be pointless?
 Pls help and thanks in advance!
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/698233-science-help/
