K65 smaller keys than k70?
Solved by Guest,
27 minutes ago, Xreldo said:
I just relelised that its actually true if you look at the both k70 and k65 the corasair logo starts at the gap between f6 and f7 while the k65 start in the middle of f6 which means the k65 has smaller keys (and no they didnt move the corsair logo its in the same place as the k70) rip me trying to fit a Qck mat and a k70 on my desk ill do it somehow.
No it isnt, the K70's logo is just smaller (K70 overlayed on K65 with slightly different angles).
You can see on the screws compared to the escape key that the size is the same.
