I was looking into buying a new headset and came across the Corsair voids which are wireless. I assume wireless headset use bandwidth to send audio to and from the headset but correct me if im wrong. I have pretty garbage internet so I was wondering if that would affect the quality of the audio sent to/from the headset.
https://linustechtips.com/topic/698010-wireless-headset/
Ehh, no.
It uses bluetooth or other radio waves to send audio.
It doesn't depend on your internet connection.
(that would suck :P)
May the force be with you - Yoda
https://linustechtips.com/topic/698010-wireless-headset/#findComment-8931550
