I posted this yesterday and got an answer but it isnt quite the answer I was expecting:  Playing a lot of games I press [ctrl] and the windows key a lot on accident at the same time. This is a problem because when I do that I also press the right arrow key. So I end up pressing [Ctrl] [WinKey] [arrowkey] and it switches my page to a new desktop or whatever. Is there a possible way to turn that off??? Thanks
https://linustechtips.com/topic/696935-re-post/
https://support.microsoft.com/en-us/kb/216893
Depending on how much you use the Windows key, you can just use that to disable it and leave it that way. It also provides a way to enable it again, though. Some keyboards (normally gaming or otherwise high end boards) have a toggle to disable the Windows key.
https://linustechtips.com/topic/696935-re-post/#findComment-8921919
