GTA + 970 = Frame Drops (Please help...)
Go to solution Solved by Flashie,
REDDIT IS A LIFE SAVER!
https://www.reddit.com/r/GrandTheftAutoV_PC/comments/43ilps/best_gta_5_settings_for_the_gtx_970_hands_down/
No more lag spikes :D If someone has a Reddit account please thank this guy on behalf of me ;)
Hi
My GTA has always run perfectly on my current config without drops. It started two to three months ago with my frames constantly dipping, freezing and resulting in frames as low as 1 fps.
My current in-game settings ( Hasnt changed since the last year ):
Ignore Suggested Limits: On
DirectX Version: DirectX11
Screen Type: Windowed Borderless
Resolution: 1920x1080
Aspect Ratio: Auto
Refresh Rate: Auto
Output Monitor: 1
FXAA: On
MSAA: X2
NVidia TXAA: Off
VSync: On
Pause game on focus Loss: On
Population density: Max
Population Variety: Max
Distance Scaling: Max
Texture Quality: Very High
Shader Quality: Very high
Shadow quality: High
Reflection quality: Very high
Reflection MSAA: Off
Water Quality: High
Particles Quality: Very High
Grass Quality: High
Soft Shadows: Nvidia PCSS
Post FX: Very High
Motion Blur Strength: None
In-Game Depth of Field Effects: On
Anisotropic Filtering: X16
Ambient Occlusion: High
Tessellation: High
Need I state this for any tl;dr commenters - All my settings are the Default settings.
My systems specs:
Motherboard: MSI Z87-G43 Gaming
CPU: i7-4790K (4.0GHz)
GPU: MSI GTX 970 Armour  4GB GDDR5
Memory: Crucial Ballistix Tactical Tracer 1866MHz 8GB (Dual channel 2x4GB)
PSU: Antec Edge Silence 750
x2 SSD's (One for Windows; One for GTA)
x2 HDD's (One for Steam; One for backups)
When I play GTA - as previously shown in this forum - GPU usage drastically spikes down to 1 or evens 0% usage.
Memory usage chills around 85% to evens 97% usage when playing GTA - But has no correlation to when drops/spikes occurred such as the GPU which had a direct correlation.
What i've tested sofar:
Verifying integrity of game cache (No effect)
Reinstalling Steam (No effect)
Redownloading GTA V Clean (No effect)
Transferring GTA V to my SSD (No effect)
Updating and Rolling back of GPU Drivers (No effect)
Reinstalling Windows (No effect)
Popping in a clients 4GB 1333MHz memory sticks (No more spikes occured - But before you go and comment "Buy more memory" Tell me why it would suddenly be spiking and dropping because of memory; if it hasnt for the past 2 years?)
Replaced thermal paste on GPU and CPU - Non coductive: Added a 120mm fan to case for better air flow
If you've read up to here - Thanks
Appreciate any help
Edited by Flashie
Forgot to add the cleaning to the list of fixes completed
https://linustechtips.com/topic/696646-gta-970-frame-drops-please-help/
