I am about to buy some RAM but the RAM I want says it goes 2400mhz (Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit)) but my motherboard says RAM speed says it only goes up to 2133 (ASUS Intel B150 Pro Gaming Motherboard) Should this be a problem?
Thanks.
https://linustechtips.com/topic/696509-ram-speed/
No it will just run at 2133 speed
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/696509-ram-speed/#findComment-8918620
Thanks.
No. The speed will downgrade to 2133hz. It'll work fine, just no point to buy 2400.
My Current Rig:
CPU: Intel Core i5-6600K CPU Cooler: Cooler Master Hyper 212 EVO GPU: ASUS STRIX OC 1070 Motherboard: MSI Z170-A Gaming M5 Memory: Corsair Vengeance LPX 2 x 8GB DDR4-2400 Storage: A-Data Premier 240GB SSD/Seagate Barracuda 2TB 7200RPM Case: NZXT S340 PSU: Corsair RM750i Monitors: Acer R240HY/ Dell S2716DG
https://pcpartpicker.com/list/xwcjLD
https://linustechtips.com/topic/696509-ram-speed/#findComment-8918622
