My friend's starting a build, want to check if all the parts are compatible before going ahead with the purchase.
https://pcpartpicker.com/list/2znJm8
Any components that should be swapped out?
Also, I wanted to know, is it worth getting the 6400 core over the 6500 one?
On paper it's a huge increase from 2.7Ghz to 3.2Ghz, how much difference does this even make?
Thanks!
Edit:
Gonna be gaming at 1080p, hence the monitor
Not so much of triple A titles and more of mobas
970 because my friend got one as a gift.
Edited by shinlos
Updates
https://linustechtips.com/topic/696052-need-feedback-for-a-build/
Why a GTX 970, get a GTX 1070 instead.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Thanks!
No 970 rx480 or 1060 is much better. Or with that priceframe go with a 1070.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
1 minute ago, shinlos said:
oh, forgot to mention, my friend already has a 970 as a gift, which was the reason for starting this entire build.
Oh okay.
زندگی از چراغ
3 minutes ago, Dawson Wehage said:
You mind if I fix up your build a bit, whats the budget?
yeah sure thing! Was planning for around 1k++, since the graphics card had already been settled.
Going to be used for gaming, less so on the triple A titles and more on the mobas
Hows this build, it's even more powerful then the other one you made, and since you already have the 970 it lowers the price.
PCPartPicker part list: https://pcpartpicker.com/list/V6qJm8
Price breakdown by merchant: https://pcpartpicker.com/list/V6qJm8/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($49.99 @ Newegg)
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard  ($134.99 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($77.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($79.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (Purchased For $0.00)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case  ($62.99 @ NCIX US)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ B&H)
Monitor: LG 25UM58-P 25.0" 75Hz Monitor  ($159.00 @ B&H)
Keyboard: Corsair K70 Wired Gaming Keyboard  ($129.99 @ Corsair)
Mouse: Logitech G402 Wired Optical Mouse  ($34.99 @ Amazon)
Total: $1088.80
Generated by PCPartPicker 2016-11-24 12:45 EST-0500
lttstore.com
Total: $1088.80
And I added a Ultrawide 1080p 75Hz monitor.
lttstore.com
Hey thanks a lot!
I think I'll swap out those parts for the ones you recommended.
As for the screen I'll just get her to pick out something else at a lower price range than the one she initially chose then haha
Anyway just a quick and random side question, any chance of throwing a Noctua D15 cooler in that case?
Just now, shinlos said:
Hey thanks a lot!
Um I think it may be possible. Just check on the websites and see the height of the cooler and see how the case can fit it.
lttstore.com
oh alright!
btw, would you happen to know how much of an impact having an i5 6500 3.2Ghz over a 5400 at 2.7Ghz?
still quite curious to know how the different clockspeeds can affect performance
5 hours ago, shinlos said:
oh alright!
Well I think it will have a beneficial impact while gaming, resulting as the cool kids say, Higher FPS.
lttstore.com
