Case led lighting
Go to solution Solved by fjdhdhcyfhf,
whatever you choose do not get something like the phanteks LED strip. the way it is made; under pressure it fails and the SMDs loose contact. there are LED strips that have braided lines and this style is better:
GET THIS STYLE ^ & i think this is actually NZXT branded
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913435
the pahanteks led strip i mention is a silicon infused rope with SMD components. under pressure the SMD components pop out and everything after that componenet looses power
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913441
That is indeed an Nzxt strip, available in 1 or 2 meters, was looking at them just last night :P
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913461
get it if it is under the cost of a box of beers. if it costs a box of beers you can buy some LEDs and make one yourself :P. 1m was enough to cover the front side, top side, and back side of my window and light everything up; there was no need or space to cover the bottom side. throw in some money for some silicone sealant to fix it; that is what i used; might be too permanent for some :)
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913489
They were I think £9 or £10 for the 1 meter strip, a box of beer is £8 - £16 depending on how many you want xD and what case was that in? i'm using an s340
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913494
go fot it and on your way out of the shop you can give a homeless guy the change. it was a P400S; it should be the same size window
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/695912-case-led-lighting/#findComment-8913503
