Need help deciding earplugs
Solved by the crunchiumo,
5 minutes ago, BaconRace said:I live in Norway so unfortunately I can't purchase anything from amazon. Anything else? I don't mean to be picky or nagging. Sorry about that.
no problem. as im unfamiliar with the types of tracks you listen to. a solid recommendation would be the audio technicas, the im02, im 50 and im 70. the newer series, e 50 and e 40 are also great options. if u want sennheiser, the cx 5 is really nice the momentums are also really great.
