budget? wait.. litterally 6?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/695368-help/#findComment-8908455
2 minutes ago, Skittleslovers02 said:
1. Around 400-600 CAD
2. Flight Sim
http://ca.pcpartpicker.com/product/fKp323/msi-geforce-gtx-1070-8gb-video-card-gtx-1070-gaming-x-8g
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/695368-help/#findComment-8908471
ok thanks. Could He Use Any 1070? Also Could The 1060 Work?
any 1070 would do, they would perform similarly. i think a single 1060 could not handle all those pixels, 6 monitors is a lot
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/695368-help/#findComment-8908488
1 minute ago, Matias_Chambers said:
But that thing only has 3 DP ports, 1 HDMI and DVI
i cant find a GPU powerfull enough to power those 6 monitors.... its the best i could recommend actually. i dont know if his mobo supports SLI
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/695368-help/#findComment-8908496
1 minute ago, Skittleslovers02 said:
All His Monitors use HDMI. DP to HDMI cables (1 DP to 3 HDMI)
then a 1070 would be your best bet
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/695368-help/#findComment-8908499
6 1080p monitors is almost twice the resolution of 4K gaming. 4K has 8 million pixels, 1080p has 2 millions. that makes 12 million pixels for 6 1080p monitors. I think that for smooth 60 fps at high or max settings 1080, 1080 SLI or Titan XP is really the only solutions, unless you cant get two used 980Ti's. Sorry, but multimonitor is expensive.
https://linustechtips.com/topic/695368-help/#findComment-8909653
