39 minutes ago, evilside123 said:
I need help please, My h220-x has algae.
How do I flush this annoying algae? My windows is cloudy.
Please help. I will attach pictures soon. I have no camera for now.
pretty sure you can take the tubing off
worth a read
ihttp://www.dslreports.com/forum/r24959933-Cooling-How-to-remove-algae-from-a-watercooled-system
http://www.overclock.net/t/740318/cleaning-your-loop-after-bacterial-algae-infection-with-pictures
http://arstechnica.com/civis/viewtopic.php?f=7&t=624319
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/694677-help-for-aio-cooler/#findComment-8902285
Thanks for those articles I really appreciated it.
I'm really not concerned about the tubing. I can change that next time, but what I am really concern about is the window. Algae is sticking in the window of my h220-x I don't have any idea how will i get that. And I noticed that there is some brown thingy in my radiator.
https://linustechtips.com/topic/694677-help-for-aio-cooler/#findComment-8902305
