Ethernet Cable Tester
Solved by W-L,
1 minute ago, Comic_Sans_MS said:I have had Cat5e Ethernet cables before that have maxed out at 100Mb
So there is no way to test a cable if it is capable of a specific speed, so I should buy proper brand Ethernet cables from a real store that I can trust?
In general there is hardware for testing that but not consumer level stuff, your best option is to get decent quality cables and test it between two system or your networking equipment.
