CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($284.98 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.98 @ DirectCanada)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($209.99 @ DirectCanada)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-3200 Memory  ($129.99 @ Newegg Canada)
Storage: Intel 600p Series 512GB M.2-2280 Solid State Drive  ($189.99 @ NCIX)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($62.95 @ Vuugo)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($569.99 @ DirectCanada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($79.99 @ Newegg Canada)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Newegg Canada)
Case Fan: Corsair SP140 49.5 CFM  140mm Fan  ($12.99 @ Amazon Canada)
Case Fan: Corsair SP120 57.2 CFM  120mm Fan  ($9.99 @ Amazon Canada)
Monitor: LG 29UM58-P 29.0" 75Hz Monitor  ($294.99 @ NCIX)
Total: $1996.79
Generated by PCPartPicker 2016-11-21 19:39 EST-0500
get the software off of microsoftwaresawp or kinguin.
added an nvme drive instead of ssd changed the psu and yeah
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/694436-first-pc-build/#findComment-8899860
downgrade to a much cheaper 1tb (this will last you a while and you can always add more storage) and invest in an ssd. That will definitely be able to play games at high resolution.
The only reason I'm here is that I have homework that I don't want to do
PC  Specs   CPU: Intel Celeron N3060 |GPU: Intel HD graphics 400 |RAM2 gigs  |STORAGE16 gigs
It took me half an hour to find where to change my signature :(
https://linustechtips.com/topic/694436-first-pc-build/#findComment-8899885
17 minutes ago, mpsparrow said:
Get an SSD.
^ otherwise its pretty solid. Not sure on that psu quality but I'm sure its fine. ?
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/694436-first-pc-build/#findComment-8899923
Honestly you'd be better off getting a WD Blue drive over a Red one being as Red ones are designed for NAS builds. Unless that's what you're building then I'll exit stage right.
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RTX 3080 OC MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD + 4TB Crucial SSD HDD:None PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
https://linustechtips.com/topic/694436-first-pc-build/#findComment-8900352
