This is my second build and everything was been fine for a month but this morning I went to turn my PC on and its not working... Only the LED strips and front case fan power on, both are powered by a molex, I can also see a small led light on my motherboard but nothing else is powered on, every part is new and ive been using it for 6+ hours daily for a month now without problem so I doubt anything has failed, any ideas?
https://linustechtips.com/topic/694238-help-pc-not-turning-on/
5 minutes ago, NinJake said:
Have you tried reseating the RAM? You can try taking out your GPU and attempt to power on running your iGPU.
What type of power supply do you have?
GPU - EVGA supernova 550 g2
I tried that and also tried remove cables and putting them back in
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8897579
I found this with a quick search. You can give this a try while I'm away if you want.
"hey man just got this mobo yesterday. what you have to do is remove the CMOS battery and put a jumper cap to reset the bios. Leave the battery out for a good hour to be sure. Dont forget to also unplug the power cable. Good luck! " - Reddit poster
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8897648
15 minutes ago, NinJake said:
Did you mean your motherboard is a msi h110i pro ac? @Ilyas123 I'm about to take lunch.. I'll look into it when I return! But you can always reference the mobo manual if you have it still.
I cant find the cmos battery on this mobo
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8897710
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8897883
Here is your manual. Read the part about "reset CMOS"
M7995v1.3.zip
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8897915
3 hours ago, NinJake said:
Glad to hear everything worked! Don't forget to mark this as a "solved" issue.
lol it worked but after about 5 hours of use it went back to how it is now and I tried to reset cmos again but I think it has nothing to do with that anymore it just randomly sometimes starts working and sometimes doesnt.. Oh well still got warranty
https://linustechtips.com/topic/694238-help-pc-not-turning-on/#findComment-8903407
