Okay some of you may have helped me before but now I'm not such a noob considering computer equipment. Finding my self in the position to upgrade, I've been saving up to 1,890$ (Not there yet though) And I've done extensive research spanning the whole last this week, knowing I've compiled a list of components that I think will suit me just fine. But before I do anything, let's get few things out of the way: I might utilize liquid cooling in the future, yes I'm building two computers at the same time, no I don't have time limit for building anything, and I'll be buying each component at a time or so. With that out of the way I'd like your guys' opinion on this sort of thing. I'll be attaching a link. Don't worry the link is entirely virus free, I wouldn't do that.
P.S. I've updated my Pcpart Picker builds, so they are better, and cheaper.
https://pcpartpicker.com/user/Vintaage/saved/
Edited by Vintaage
Missing Info/ Updated links
Many people view me as a chimera, I may or may not exist...
https://linustechtips.com/topic/693814-pc-help/
just some tips.
why dual R7 370s? just get a single GTX 1070 or something cheaper.
you can buy windows for cheaper on Kinguin.net.
good luck with your build! :D
My computers as of 2017/03
My Old PC
Dell Vostro 260 $150 2010
CPU: i3-2120@3.3Ghz, GPU: Intel HD Graphics 2000, ATI Radeon X1300, RAM: 4GB Axevir Budget Series, SSD: 240GB Radeon R7, HDD: random 250GB and random 160 GB, CASE: Crap from Dell, OS: Windows 7 Enterprise
My Current PC
Custom Build $1200 2016
CPU: i5-6600k@3.6Ghz, GPU: Sapphire R9 Fury, RAM: 16GB Geil EVO X, SSD: 240GB Radeon R7, HDD: Hitachi 500GB, CASE: Deepcool Kendomen, OS: Windows 10 Professional 64-Bit
Laptop
ASUS F8S $1150 2008
CPU: Core 2 Duo T7500, GPU: ATI 2400 Mobility, RAM: 8GB Mushkins, SSHD: 1TB Seagate Hybrid Drive, OS: Windows 7 Ultimate N and Windows 10 Professional
HTPC
MSi Cubi $200 2016
CPU: Pentium 3805u@1.9Ghz, GPU: Intel HD, RAM: 4GB Crucial DDR3L, SSD: 120GB Radeon R7
Other Laptop
HP 2210b $400 2009
CPU: Core 2 Duo T8100@2.1Ghz, GPU: Intel GM965, RAM: 2GB Hynix, HDD: Hitachi 160GB, OS: Linux Mint 17.3 and Lubuntu
*All Prices in the Canadian Dollar
https://linustechtips.com/topic/693814-pc-help/#findComment-8893503
http://pcpartpicker.com/list/7Rh7pb
for your other build, I would get another cheaper hard drive, because 65 seems alot for a 1tb drive.
My Old PC
My Current PC
Laptop
ASUS F8S $1150 2008
HTPC
MSi Cubi $200 2016
Other Laptop
HP 2210b $400 2009
https://linustechtips.com/topic/693814-pc-help/#findComment-8893524
http://pcpartpicker.com/list/rYzPgL
update on your other build, mostly the same
You don't really need case fans because both of those cases do come with them.
My Old PC
My Current PC
Laptop
ASUS F8S $1150 2008
HTPC
MSi Cubi $200 2016
Other Laptop
HP 2210b $400 2009
https://linustechtips.com/topic/693814-pc-help/#findComment-8893576
That's because it's 2TB
https://linustechtips.com/topic/693814-pc-help/#findComment-8904790
Thanks, but they are for replacement, I just trust those ones over factory models
https://linustechtips.com/topic/693814-pc-help/#findComment-8904797
