I found a good price for some DDR4 ram - http://www.amazon.in/dp/B00SV7IILC/?tag=pcp03-21
But in case I face any problem with it, it will take a lot of time for RMA, as the store is physically very distant.
So my question is, should I go forth and buy it? How often do we get problems with RAM? (If at all)
Thanks!
https://linustechtips.com/topic/693108-how-often-does-one-get-problems-with-ram/
Unless you're bad at plugging things in, nothing should go wrong.
Run memtest on new sticks to make sure they pass a few runs.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
never had any problems in my case
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Thanks! Also do you recommend that RAM stick which I mentioned?
Head over to PCPP to get prices on all RAM and see which ones have the best value for the dollar.
1 minute ago, Vishvas Sudarshan said:
The link which I have pasted, that's the first 8GB stick. When I sort - Price/GB
Is it the best speed (bandwidth) and CAS latency in the price range?
13 minutes ago, Vishvas Sudarshan said:
I don't know what CAS is, PCPP says its 15. My mobo only supports upto 2133MHz
Should be the best one aside from the aesthetics.
