Hello all! I'm planning to build a PC for moderate gaming (nothing much more graphics intense than minecraft), some virtualiztation (most likely not more than one VM at a time), and general use. I want to make it a little bit better than what I need, so I can "grow" into it. Here are the parts I'm planning to use so far:
Processor: Intel Core i5 6600K 3.50 GHz Quad Core Skylake
Motherboard: ASUS ATX DDR4 LGA 1151 Z170-E
RAM: Ballistix Sport LT 8GB (X2 4GB sticks) DDR4 2400 MT/s
Hard Drive: WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch
Power Supply: Cooler Master Elite V2 - 550W
Case: Cooler Master HAF 912
Please let me know if there is some incompatibility, or if I'm missing something important. Also, feedback is welcome :)
Thanks in advance!
https://linustechtips.com/topic/692977-midrange-pc-build-help/
That PSU is not compatible with your own safety man, grab a Seasonic S12II 520W for $54.99 over at newegg.
And I wouldn't do the HAF 912 unless it was $40 or less, it's got a bit of a dust collection problem. Instead a NZXT S340, or for less a Corsair 200R.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/692977-midrange-pc-build-help/#findComment-8885749
Thanks Energycore, I'll check those out! Thanks for telling me about the dust collection problem, I didn't even think to check for that. HoneyBooBoo, I'll consider getting a GPU, it might set me a bit over budget, but I will get one when I start gaming on it. And as for OC, I will expirement with that a bit. And if I do OC, do you think the 6600k is worth the extra $30ish over 6500?
https://linustechtips.com/topic/692977-midrange-pc-build-help/#findComment-8885773
