HI ALL IM BASICALLY NEW ON EVERYTHING AND I STARTED TO BUILD MY FIRST DESKTOP GAMING PC AND I AM STUCK ON GRAPHICS CARDS
GTX 1070 OR GTX 980TI THOSE TWO CARDS ARE PRETTY POWERFULL TO PLAY FULL HD  OR 1440P (WHAT WHAT I AIMING FOR ) I CHECK PLENTY OF VIDEOS BETWEEN THOSE TWO CARDS BUT STILL I AM CONFUSED AF ,AND ALL NEW TECHNOLOGIES SUCH AS PASCAL COME TO FRONT .
BUT I ASKING FOR YOU GUYS WHICH CARD YOU CHOOSE.
The parts i am going to use:
motherboard-
ASRock FATAL1TY B150 Gaming K4
NZXT NOCTIS 450 MID TOWER CASE
INTEL I5 6600K
16GB RAM (2133)
AND COUPLE SSD
AND  LIQUID COOLING FOR INTEL I5
AND 500-550 W POWER SUPPLY
THANKS ALL.AND SORRY FOR SPELLING.
https://linustechtips.com/topic/692687-help-to-choose/
no need for capslock, no need to scream, we'll help you out even without big letters. And welcome to the forums :)
get the 1070, more features, more vram, better performance.
one note for your planned build: you will not be able to overclock the 6600k with a b150 chipset motherboard, you need to get a z170 board
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8882833
Thanks a lot.I like 1070 aswell but the cheapest one i can find is about 400 pounds (lots of money) Yea I start to noticed that,but I am gonna build PC for gaming not for overclocking (maybe because I am not really used before and a little bit scared) but I was checked a z170 ASrock fatality aswell so still thinking, I only got a Case power supply, keyboards and monitor so other parts still in the buying list. But i look at that I can afford aswell.It's gonna take a while when I finish but i want to make the best I can.
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8882860
Thank you.
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8882880
other thing I would like to make black and red theme gaming pc but the on the nzxt case is stock fans without red leds if I put other ones with red leds which I need to choose to perform same airflow and add some extra spice?
Or its doesn't really matter?
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8882973
Overclocking = better performance in gaming. It's also incredibly simple. But if you don't plan on that, go for an I5-6500 and you won't need liquid cooling.
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8882988
At the moment no but like I mention uper posts I still not yet have everything only a case monitor and keyboard so I might have change the mind..So do so I have to have a Z170 board? And does the 6600K good for overclocking?
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8883003
If a processor has a "k" in its name, it can be overclocked. If you do get one of those, a Z motherboard facilitates overclocking.
If you do not wish to overclock, a B150 motherboard and I5-6500 are a better route to go. It'll do exactly what you want and save a few bucks.
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8883308
hmmm ..Interesting.Dpes Z motherboards have apps to hel poverlock those processors ? Cuz i check plenty videos of linus and it seems in some ocasions doesnt really matter if you processor overclocked or not.. And if i still decide to stay on non-oc why i dont need a cooler (liquid all in one)
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8885575
If you don't plan on overclocking , why pay extra for things you will not use? It would be like buying a Ferrari if you only drive 2 miles a day, every day.
You don't need to buy a cooler with an I5-6500 because it comes with one. A non-overclocked processor will not generate the heat that would necessitate the use of liquid cooling or a 3rd party air cooler.
The BIOS in a Z motherboard will allow overclocking.
https://linustechtips.com/topic/692687-help-to-choose/#findComment-8887353
