Hello,
building my first rig, I bought a Fractal design define S and a corsair RM750x PSU. The case has excellent noise dampening, including anti-vibration foam mounts for the PSU that also double as an insulator for electric current. With the PSU being grounded by the plug, should I additionally ground the case on the PSU or is it OK to leave it as it is?
thank you
Asus Prime X570 Pro | AMD R9 3900X | Corsair Vengeance LPX DDR4 32gb 3000MHz CL15 | Asus Strix GTX 1080 A8G | Samsung 970 Pro 1TB | WD Black 2TB | Corsair RM750x | Noctua NH-D15
https://linustechtips.com/topic/692025-compter-case-grounding/
10 hours ago, M.Yurizaki said:
It should be fine. If you're really anxious about it, grind down some of the paint off the case and PSU near the screw points.
The foam is all around the opening, so i can't, but I believe the screws themselves will do the trick.
thanks for the answer.
https://linustechtips.com/topic/692025-compter-case-grounding/#findComment-8877444
