I was wondering im building my first pc and was wondering if I should water cool or just do the normal AIO for cpu and for GPU air cool
PCPartPicker part list: http://pcpartpicker.com/list/Bp9HRG
Price breakdown by merchant: http://pcpartpicker.com/list/Bp9HRG/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($428.99 @ SuperBiiz)
CPU Cooler: CRYORIG A80 128.0 CFM Liquid CPU Cooler  ($105.00 @ Newegg)
Motherboard: Asus X99-A II ATX LGA2011-3 Motherboard  ($223.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-3200 Memory  ($199.99 @ Newegg)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($312.95 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($118.99 @ SuperBiiz)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Extreme Video Card  ($670.53 @ B&H)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($138.33 @ OutletPC)
Monitor: Asus PB278Q 27.0" 60Hz Monitor  ($385.98 @ Newegg)
Monitor: Asus PG279Q ROG Swift 27.0" 165Hz Monitor  ($734.99 @ Best Buy)
Total: $3795.70
Generated by PCPartPicker 2016-11-14 10:40 EST-0500
https://linustechtips.com/topic/690742-cooling/
I would recommend water cooling. If you're putting all this money into a good unlocked CPU and GPU, I would be sure to have a decent liquid cooler so I can overclock to the fullest potential - I know it's your first build but it wasn't long before I decided to overclock after my first build.
https://linustechtips.com/topic/690742-cooling/#findComment-8860173
That simply relies upon how intensely you expect to overclock.
- If you don't overclock, you could just use the stock cooler or a small air cooler such as a Hyper 101i
- if you plan to do a "normal" overclock - the sort of OC that you can get by just clicking on "OC my ride" in the BIOS - an air cooler such as a Hyper 212 or a basic 120mm AIO would do
- it's only if you plan to do an extreme overclock that you need to get into a 240/280mm AIO or a custom water loop.
For your 1st PC build I would suggest you only do a "normal" overclock (if any)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/690742-cooling/#findComment-8860179
