I started this topic before, but only 1 guy replied, so I'm doing it again.
I have an external hard drive with USB 3.0, and some more USB 2.0 Storage devices available, that I want to transfer data on. Yes, I know, USB 2.0 is ANCIENT. but please help a fellow brother out. EVERY SINGLE STORAGE DEVICE I OWN ACTS THIS WAY. (Except for those attached from SATA). When I transfer data, the speeds go high, in the 150 - 200 range in my External drive, and then a minute or two later it bumps down to 27 Mbps. It takes HOURS to transfer large amounts of data. I play heavy games, so my range is 14 - 50 GB of data being transferred. Before you answer, this is a screenshot of what my computer storage management looks like in Computer Management.
Please help me. I have been looking for AGES and still don't know what to do.
It is said that an Italian dies every time Spaghetti is broken.
That's why I break mine twice.
https://linustechtips.com/topic/690283-random-read-and-write-speeds/
Depends on the size of the individual files you are transferring.  The smaller they are, they slower you'll transfer.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
You're likely hitting the cache limit for the drives in question.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I have an SSD in my PC, which shows correct read and write (according to crystal disk mark) and I have an HDD in my PC that also functions correctly. Only External devices malfunction for some reason. If I am hitting the cache limit, how do I increase it? My specs of my pc are under this comment, so you can check what you need to, if it is something like RAM or the motherboard.
The cache is the RAM on the device's controller. It cannot be increased and synthetics won't show real performance for transfers.
