My core temps average between 65C-75C. At 4.4 ghz and 1.25v.
Which i think is great for this cpu idk yet. (i7 5820k)
However, my cores sometimes spike to higher temps
So far after 50 mins stress test
Max
83C
78
86
80
87
77
But they stay around 72C generally.
Is it bad that they reach a high temp for a sec and than go back down?
Will that degrade my cpu?
i have a cosiar vi100 water pump btw.
Also quick question. I installed an m.2 SSD vand Samsung 850 evo, and my computer OS nor Bios can detect it. I found out that the motherboard support does not show support for it, but neither does my Ram and it still works with overclocking.
Is there a way for this SSD to work for my computer? Is it possible that in the future with bios update it will work?
https://linustechtips.com/topic/689099-streas-test-highest-temp-vrs-average/
what mobo is it. some mobos don't support non pcie based drives in m.2
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
temps looks fine. Seems right below thermal throttling range (85-95 usually).
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
1 minute ago, PainBlame said:
Gygabyte ultra gaming rev 1.0
I saw that it doesnt support it but neither did my ram, however my ram works fine.
ram is basicly universal m.2 is not. it will never work
The ram still uses the same protocol, just at a different freq. That's a much easier compatibility category than a completely different protocol. Your mobo won't support any sata m.2 drives, something like a 950 pro would've worked nicely.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
My mobo has a 10 gb/s m.2 slot. It also has an m.2 wireless slot. Their is a support list for m.2 SSDs on their website. However mine is not on the list. Which really sucks cause this cost $150. I would have gotten a sata port 2.5 inch ssd but i didn't want to pack my case unless i had too. I found out my ram is listed in the mobo but it runs at 2400 mghz stock, at 1.2v. Its not till i XMP it to 3200mghz at 1.35v.
Also during a stress test for cpu and RAM. My ram isn't surpassing 1600 mghz. Does anyone know why?
All the m.2 drives listed are PCIE interface, whereas your drive uses the SATA interface. m.2 is not universally compatible with all m.2 drives because of the interfaces. As far as compatibility lists, for RAM, all modules should use the same interface (DDR3/DDR4) so as long as the modules are of the same interface type, and supported voltage range, they should be compatible even if not on the list but may run at lower or higher frequency depending on settings.
Your RAM is running correctly. Most software reports actual frequency where BIOS will show effective frequency. DDR stands for dual data rate, which basically means a RAM module with an actual frequency of 1600MHz will have an effective 3200MHz.
That ram makes sense, i didn't even think about 1600 being half of 3200 mhz. Its just bugging me. Thanks
