Recently bought 3 kingston data traveler usb 3.0 drives from the egg, plugged them in and ran checkflash to verify integrity. Strangely enough, all 3 drives came back with the same 4 errors after a full pass. I've attached a screenshot of this strange phenomenon. Not sure if bad drives, or just a coincidence.what.jpg
Update: ran test again, no errors on any drives. Wat?
https://linustechtips.com/topic/689043-weird-flash-drive-errors/
6 hours ago, Straxxus said:
~snip~
Hi there :) Welcome to the community!
What are the drive's brands and models? Do you encounter any issues with using them? The error may ave been caused by a driver conflict or some other thing which is not necessarily connected to the drives themselves.
Try contacting the manufacturer for other ways to test these drives.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/689043-weird-flash-drive-errors/#findComment-8844025
