Hello, I've built my pc about 3 months ago, and I'm starting to see some dust in my pc and keyboard. I'm gonna choose one out of three options. Please help me choosing.
1. compressed gas duster can
2. electric duster
3. a hairdryer that doesn't shoot hot air(cheaper second option)
https://linustechtips.com/topic/688169-pc-cleaning-help/
Compressed air can or electric duster are your best options. The compressed air can will get expensive if you use it a lot. The electric duster will have a higher initial cost but if you're cleaning your computer on a weekly basis it will be more worthwhile over the duster after a few months.
https://linustechtips.com/topic/688169-pc-cleaning-help/#findComment-8832870
Build that wall
http://pcpartpicker.com/list/Mf3Zcc My build
R.I.P Donny- Got banned. We will always remember your spamming of "Cancerbooks"
iPhones are like 1 ply toliet paper with a logo slapped on them and years old hardware in them- A Wise Man
https://linustechtips.com/topic/688169-pc-cleaning-help/#findComment-8832874
Is there any problem with third option?
https://linustechtips.com/topic/688169-pc-cleaning-help/#findComment-8832879
9 minutes ago, PCNoobie said:
-snip-
I would recommend a can of air because conveniently enough.... I also need advice as I plan to clean out my PC and Keyboards within the next week or maybe two.
Reason I say this is because I'm in the same place as you, I haven't cleaned it (My PC) in a while so I hope that nothing bad goes wrong for the both of us :D:P
But yeah, I wouldn't risk using #1 or #3 and would watch some YT Vids from those who use a can of air to clean a PC ^_^ That's probably what I'll be doing lol.
Quote
Edited by Xiauj
Hey I'm Xiauj ^_^ Wassup :3
https://linustechtips.com/topic/688169-pc-cleaning-help/#findComment-8832893
