So I am making a build its for my job which is Rendering/editing and extreme/hardcore gaming so here is a list and I want to know if its good and I also want to know if I can get something better for a better price so here are my specs and of course everything including the pump,coolant and tubes are included in the budget even the monitors,peripherals and OS, also most of these I am buying from NCIX, and no not because Linus works there because none of these items are near me and I want to buy all the items from just 1 store, also my budget is 6000-6500 US Dollars. Ive been saving for 2 years and I have been using quite a not so beefy machine from the company I am working in
Motherboard: MSI Big Bang Xpower II/ASUS Rampage IV Extreme
CPU: Intel core i7 3930k
CPU Waterblock: Swiftech Apogee HD
RAM: x2 Mushkin Blackline Frostbyte 16GB 4x4 Quad Channel Memory 1600Mhz
Graphics Card: x2 MSI GTX 680 Lightning 2GB
GPU Waterblock:XSPC GTX 680 Full Water Block
GPU Backplate:EK-FC GTX 680 Full cover backplate
Powersupply: Corsair AX1200I
Case: Silverstone Temjin TJ11
Storage: HDD: 4x Western Digital 2TB Green in RAID10
SSD: 2x Kingston 3K 240GB in RAID0.
Optical Drives: NZXT Sentry Fan Controller
ASUS BC-12B1ST Blu-ray Reader
ASUS DRW-24B1ST DVD Writer
Pump: Swiftech MCP655
Quadruple Radiator at Bottom of the case: Swiftech MCR 420 Quiet Power Quadruple 120mm
Radiator Fans: Silverstone Air Penetrator AP121-BL 120mm
Reservoir: Swiftech MCRES-MICRO-R2
Radiator (at the top of the case): Swiftech MCR120 Quiet Power
Single Radiator Fan: GELID Wings 120mm
Tubing: Primochill C-34 AQ UV Aqua Blue
Sound Card: ASUS Xonar Essence STX
Monitors: 2x ASUS VE278Q 27" LED Backlit
I dont know if I can find water cooled RAM and the RAM Water block but I wish I can find one
https://linustechtips.com/topic/6879-my-watercooling-project/
You'd have to double check with someone like Ghost or Whaler99 but from memory the MSI 680 Lightning uses a custom PCB meaning that standard 680 waterblocks are not compatible. Other than that I don't see any major issues. You may want to drop to a 860w PSU as high wattage single rails can end with devastating consequences.
https://linustechtips.com/topic/6879-my-watercooling-project/#findComment-73804
Yeah ok I will drop to a 900w and change my Waterblock and Backplates and I will change the greens to reds oh heres a good question I plan to do that RAID configuration for the SSD's to be put in the back of the motherboard tray but I need to know where to put the 4 Red 2TB ?
https://linustechtips.com/topic/6879-my-watercooling-project/#findComment-73826
