Sigh....
Any ideas?
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/68768-problem-installing-81/
i searched the issue, and apparently it has to do with nvidia drivers. Not everyone is successful, but most people are getting around it.
Please completely uninstall ALL video drivers that are powering your GPU, the Nvidia driver first, then restart, then the generic nvidia driver that Windows will try to install after the reboot. then restart again. You should now be in a reduced resolution. Try the update again, if the problem persists, then just reinstall your drivers and wait for an official fix :/
It's all I got. good luck though!
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-942850
Thank you sir! Ill try it and let you know what happens :)
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-942854
Also remember to download the latest 8.1 drivers from Nvidia, as they will offer better support for 8.1.
http://answers.microsoft.com/en-us/windows/forum/windows8_1-windows_install/error-0xc1900101-0x40017-when-installing-windows/8c893ae6-0e9b-4b7d-a647-b9065099efd6
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-942860
I do have the latest drivers :)
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-942917
Have you checked the Microsoft windows compatibility website and also you know there is no upgradeable copy of the os from windows 7 just a full install version
I currently have windows 8.
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-944769
did you check the Microsoft compatibility website for all your hardware & software that might be having problems .  Question ? how did the update  run when you try to install 8.1 and is that the current system that you are running is in your Siegel
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-945190
Yes that is my current system. Everything went fine until it rebooted and was about to log into windows, then that screen popped up.
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-945202
try uninstalling  your recon  3d an try with the latest NVidia beta driver make a restore  point and let me know how it goes
https://linustechtips.com/topic/68768-problem-installing-81/#findComment-945482
