for my next build i want to use a case that is really thin just like they used on the digitalstorm bolt
http://www.digitalstormonline.com/bolt.asp
but i can't find any case that accepts a dual slot gpu while remaining flat/thin.
https://linustechtips.com/topic/68726-looking-for-a-thinflat-mini-itx-case/
I wouldn't recommend getting one. Anything that thin would be forcing you to take a proprietary PSU, and at that size the wattages would be ~400 max.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
I don't think you'll be able to find anything besides an Alienware x51 or that, bolt, or another one called a Tiki(cant remember who makes it)
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Falcon Northwest.
yep that's the one, aside from that there aren't any cases you could actually build a system in.
