Skyrim specific gaming machine
Go to solution Solved by Belgarathian,
Something like this would work well:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: ASRock H170M-ITX/ac Mini ITX LGA1151 Motherboard  ($97.98 @ Newegg)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($36.99 @ Newegg)
Storage: Western Digital Blue 1TB 3.5" 5400RPM Internal Hard Drive  ($53.99 @ Newegg)
Video Card: MSI GeForce GTX 1050 Ti 4GB Video Card  ($139.99 @ B&H)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.69 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($52.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($85.70 @ My Choice Software)
Total: $639.82
Generated by PCPartPicker 2016-11-06 18:28 EST-0500
It could be done slightly cheaper, but I've gone for parts I know, haven't skimped on a terrible PSU, and opted for a wireless capable MB.
I'm looking to build a pc for my friend who is a HUGE skyrim fan. His current pc is NOT gaming ready. He currently plays it on PS4 . He has played on my full mod version and loves it. What would be the most cost effective way to get great playability for a mod version of skyrim ? I'm not sure due to mine being overkill where the sweet spot is.
https://linustechtips.com/topic/686941-skyrim-specific-gaming-machine/
Current is an old eMachines pc. Like 4 gig ram 1.8 ghz celeron . Like I said NOT gaming at all. I have an old 1080 60hz monitor to give him (currently on an old 4:3) I'm doing this as a birthday gift . He has said multiple times how much he would live to go with pc gaming but vast afford a new pc. So figure I'll build him one. I'm just not sure of skyrim (his main game by far. I think he's on his like 6th play through ) how many cores does it use? How much vram for modded ? Which drivers are best nvidia or amd for skyrim ? I know problem is it's on dx9
I'd see if you can use PCPP and build around an i3-6100, 1050 Ti, with 8GB of 2800Mhz RAM.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Total: $639.82
Not worried about being bottom dollar . Not expensive either . I was looking at something like
PCPartPicker part list: http://pcpartpicker.com/list/W6ykjc
Price breakdown by merchant: http://pcpartpicker.com/list/W6ykjc/by_merchant/
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI B150M BAZOOKA Micro ATX LGA1151 Motherboard  ($57.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($83.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  ($72.49 @ Amazon)
I have an extra 1tb wd black I can give him
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($62.99 @ SuperBiiz)
Total: $620.30
Generated by PCPartPicker 2016-11-06 18:49 EST-0500
Total: $620.30
That works and gives him the advantage of the SSD as well. Won't be needing the CM Hyper 212 though, you won't be OCing the 6100 and it comes with a stock cooler that's fine. It's a 35W package.
I'm not overly familiar with B150 chips, you might just want to double check compatibility.
Don't get a CPU cooler and buy an MX300 275GB instead.
I've personally never had the greatest luck when it comes to crucial . But it's been a while I'll give them another shot.
And I was thinking cooler just to be quieter .
I would go with the PURE ROCK, then.
Mind if I ask what drive you used before?
Just now, Spookshow said:
I don't remember exactly it's been a few years. But I know it was a bx
The BX100 or BX200? Yea, the budget lines are pretty bad.
I've never done a B150 build myself. But looking at it looks better then H110 (I have done those) but not quite H170 (I have done 1 H170) the H110 uses PCI-E gen 2.0 and only 14 PCI-E lanes where as B110 uses PCI-E gen 3.0 and 18 PCI-E lanes. The I3 6100 supports 16 PCI-E lanes as does the gtx 1050ti. But other then that what specific compatability are you speaking of?
